CUTLASS Best way to flush/change coolant?
78Delta88
1,307
1,095
SW Arizona
Shop uses the reverse flush machine. They just plug it in and let it run and go do something else.
Just get the Prestone kit, I've used those for years.
86LK
1,978
2,043
since I'm working on my auction truck (07 Silverado) right now, does anyone know where to find the data for how much fluid a radiator holds? is it 1-1/2, 2, or 2-1/2 gallons?
note that I am not asking about total cooling system, but just the radiator
Rt Jam
595
590
Ontario Canada
Why do you want to know?
abbey castro
1,048
1,318
Harker Hts TX
It doesn't matter what the capacity is, fill the radiator to the neck, then fill the coolant return bottle to the cold fill line. Warm it up add coolant IAW coolant bottle mark. This is not rocket science so don't make it so, it isn't. Good Luck
86LK
1,978
2,043
only one problem....an 07 Silverado doesn't have a radiator cap.... it fills up via the Overflow tank
the reason I want to know how much the radiator holds is because when I do fill up I want o have a good idea of how much should be going in because there is always some unknown residual amount left in the block. I don't like playing guessing games.
abbey castro
1,048
1,318
Harker Hts TX
Utube it, there are a bunch of videos showing how to do it.
78Delta88
1,307
1,095
SW Arizona
Following is just a swag... Scientific or (Silly) Wild A** Guess. Don't know your exact specs so pulled from Rock Auto 34 x 18.125 x 1.25 Core. For tanks just extrapolated it as 3 columns = (1.25 thick x 18.125 high x 1.5 wide).
Core is 770.3125 cubic inch or 12,623.1603 CC
Tanks (SWAG) ... 67.97 cubic inch or 1,113.829 CC
Total = 13,736.9893 CC/ml = 13.74 Liters = 3.63 Gallons.
And you are probably around 60% of that = approx. 2.2 Gallons?
Still seems kind of high.
78Delta88
1,307
1,095
SW Arizona
About the only way to do it, unless you can find out actual capacity from GM books, would be to:
Remove and lay radiator flat make sure it's empty and add measured amounts of water and total that up.
Figuring the wife doesn't want her good Pyrex out in the garage, I would suggest the 1 or 2 quart plastic paint container and pour into radiator until full. Keep track of total quarts poured and total up and convert to gallons. 4 quarts = one gallon.
