braided fuel line????
83gbody
156
Oxford, Ms
What do I need to hook braided fuel line from my fuel pump to carb(edelbrock 1405) on chevy 305
GhettoRacingKid
775
7
AN lines?
youll need a fitting of pipe thread to AN. then the line with the fitting and then the same on the carb.
one issue I see is that clearance on the front of the carb for the feed might have enough room for the fittings and line
FE3X CLONE
2,714
51
48
Ohio
What kind of thread does your fuel pump have? Most don't have NPT fittings but inverted flare which means you'll need an inverted flare to -AN flare fitting for the pump.
For the carb you need to find out what thread size and fitting it takes and buy an AN adapter fitting for that as well. Those typically aren't pipe thread either but a straight thread that uses a gasket.
From there it's just a matter of buying the amount of hose you need and style of hose fittings to match.
