Hi guy I've tried searching through many posts to no avail, I'm wondering if the 87 GN accessories and pulleys fit on the Buick 350 the way the N/A 231 3.8's do? Any help or guidance is greatly appreciated. ANTOINE
Blake442 said:They should bolt up just fine, though the accessories are in a rather odd layout...
Make sure your water pump is the same length and that the balancer is the same thickness, or it will throw off your pulley alignment.
When I swapped from a n/a v6 to a Buick 350 I used a h.d. V6 water pump and everything lined up perfect.
