Car won't go over 20 mph
thedoctorisin
187
16
East Bay Area, S.F. Ca.
My cutlass did that when it had the original 260 olds motor in it. Check the intake seal. Mine would start and run, but the idle was high and wouldn't get above 20mph. At that point the car had 150k+ miles and I put in a new motor. But when I was able to get a good look at the back ofthe block I could see the intake seal along the intake and block had pushed out and was later told that it was more than likely the culprit.
J.Rod22
216
9
Georgia
seawolf18 said:
The first place to start is with the codes. Pull the codes and post them. Why was the carb replaced? I'm guessing the car went over 20 mph before the carb replacement? Did you make sure the tv cable was put back on properly?
I pulled the codes and I got codes 21,23,44, and 45.
Oct 14, 2008
8,826
7,779
Melville,Saskatchewan
Is the TV or kick down cable hooked up? Is your trans fluid level good? It should shift in limp mode, just run pig rich.
MeanBuicks
329
2
16
Memphis, TN
Are you positive you plugged all your electrical stuff back together correctly? It's really not happy with all those codes and two of them are conflicting.
Diagnostic Trouble Codes - 1988 Oldsmobile
 13  Open Oxygen Sensor Circuit
 14  Coolant Temperature Sensor (High Temp Indicated)
 15  Coolant Temperature Sensor (Low Temp Indicated)
 16  System Voltage High
 21  Throttle Position Sensor (Signal Voltage High)
 22  Throttle Position Sensor (Signal Voltage Low)
 23  Manifold Air Temperature (MAT) Low Temp Indicated
 24  Vehicle Speed Sensor (VSS) Circuit
 25  Manifold Air Temperature (MAT) High Temp Indicated
 26  Quad-Driver (QDM) Circuit
 27 Gear Switch Diagnosis
 29
 31  Park/Neutral Switch Circuit
 34  Mass Air Flow Sensor (MAF) (GM/SEC Low)
 38  Brake Input Circuit
 39  Torque Converter Clutch (TCC) Circuit
 41  Cam Sensor Circuit
 42  Electronic Spark Timing (EST) Circuit
 43  Electronic Spark Control (ESC) Circuit
 44  Oxygen Sensor Circuit (Lean Exhaust Indicated)
 45  Oxygen Sensor Circuit (Rich Exhaust Indicated)
 48  Misfire Diagnosis
 51  Mem-Cal Error
 63   Exhaust Gas Recirculation (EGR) Flow Check
 64
 65
