i have an 87 442 all factory stock, I remove the stock 307 and installing a 350 Olds. I'm not using the factory carb or distrubutor. How can I bypass the computer to run my cruise and A\C??
Uncletruck said:You'll also need a non computer throttle kicker solenoid for your carb to bump the idle up when the A/C compressor is on. Simply connect the non computer solenoid positive wire to the positive wire of the A/C clutch to get it to function. On computerized carbs, the kicker solenoid is controlled by the computer.
-Mark-
Uncletruck said:I always thought the throttle kicker solenoid was to give the engine a little idle speed boost when the load from the A/C compressor is on. (I think it performed some other things on the CCC engines.) Couldn't this still be beneficial even if one were to use a 1960's engine, or did the added HP of those old engines without a lot of emissions equipment make it unnecessary?
-Mark-
