For my new 565 BBC engine that I am going to install this Fall/Winter I have been seriously considering converting to E85 and want to hear from anyone that has done this conversion to dispel some of the "myths" that can't seem to be confirmed but you still hear.
I will list the parts I have and my concerns and this will be a carbureted application that will have nitrous.
My current fuel system is 15+ years old and I have ran full race fuel to pump gas and different mixes over the years.
My engine will be 13.6 compression and I have read as much as 15 to 1 is safe for E85
The carb I plan on using will be a Quickfuel 1250 converted to E85
I have a 20 gallon aluminum fuel cell with foam, my current foam is in great shape.
My plan is to replace the foam with E85 compatible safety foam
I have an Earls 12 AN line coming off my sump that goes into a Paxton filter and Paxton 300 pump from there I have 10 AN going to the front of the car where it enters a BG 4 port regulator and then splits off to two 8 AN lines going to the carb.
My plan is to replace the current lines due to age with new Stainless braided lines with known E85 compatibility and replace the paper filter with a stainless mesh one.
Both my fuel pump and regulator have been discontinued and I would like to rebuild them with known E85 compatible parts so that will be a little harder to do but my BG regulator looks almost exactly like Quickfuels 4 port design so maybe their kit will work.
My nitrous set up has its own fuel system which is a Mallory 140 pump/filter and this will be ran off its own 4 gallon fuel cell using race fuel.
I keep reading different things where people have had no issues when switching to E85 from race fuel and then I read ones that say the fuel eats this and that so for anyone that has done this let me what is working for you.
