Delco 1.5 CD Player... better than the tape decks power wise?
6,855
6,797
I really like the look of this radio, and to be honest I'm not opposed to having a cd unit in my car.
My question is, can this radio handle more power (bass/sub) than my current eq tape deck? Or would it be pointless to swap?
Rocknrod
All Around Good Egg
98
88
Looks like a Pontiac 1995 unit?
DSPbuilt
575
1,570
Cape Coral, FL
These are pricey but real nice.
9,292
15,763
From what I've seen inside of my CD player ('96 Camaro unit) when I replace the disk drive, it looks like it has all the same parts as my tape player ('89 Firebird unit).
pizza442
23
17
I installed this same unit (out of a 88 or 89 FWD Cutlass) into my 79 H/O in the early 90s. Found some sort of wiring adapter, Dealer only had the later (86-88) dash wood-stlye 1.5 DIN so I used that to look stock (bought a few extras which I sold years later:D) Only issue I remember was that I really had to turn up the volume much higher than what seemed normal, like I was missing an amp or something, but otherwise it worked perfectly.
Wageslave
1,750
3,342
The volume thing may have been the impedance of the speakers. 16 ohm speakers are quieter than 4 or 8 ohm speakers at the same volume setting.
pizza442
23
17
So the factory speakers in the 79 were 16 ohms? And in the 88 or 89 Cutlass they were 4 or 8? I know the factory front and rear speakers in my 72 Cutlass Sup were 10ohms, never heard of 16 tho...
Wageslave
1,750
3,342
It's been a while so I can't remember exactly what the impedance of the speakers I took out of my Pontiac were, I do know that as vehicles got newer, the speaker impedances generally went down. It wasn't uncommon to see 2 ohm speakers in the higher end Bose and Monsoon stereos and 4 ohm in the lower end systems.
