CUTLASS Dome Light Question
4
Hi everyone. I hope this is the right place to post this. I'm trying to help my neighbor out. She has a really clean 1984 Cutlass Supreme Coupe. From the research I've done, there are a couple of dome lights that were available with her model. She has the one with a single map light, like this one:
Over time, the rectangular plastic piece that holds the bulb terminals in place has gotten brittle and cracked, causing the terminals to bend outwards instead of holding the bulb. Is it possible to replace this piece? If not, what about just the mounting plate/lamp terminals, and if so, could someone supply the part numbers to maybe make finding parts easier?
The chrome part of her dome light is in mint condition (even the lens isn't too bad), so I can't justify changing out the entire light unless it's necessary.
Any info or advice would be appreciated! Thank you!
69hurstolds
8,262
17,796
GM p/n 1674098, superseded to 20717805 for the lamp base. You have to get the entire base if you find it. Can't get separate pieces of it. GM lists it as still available. Not sure though. $41.00 MSRP. I do not know if you get the wiring with it or it's just the base unit. I've got a stash of them and I'm not sure what came with them as they're buried away somewhere.
For the chrome housing, should it be needed, is GM p/n 1674097. GM still lists this as available for $30 MSRP.
Here's an NOS one on ebay, but it's erroneously listed as a base unit of p/n 1674098 (should be 097).
If anyone needs the plastic lens part, GM p/n 1674099, you can get a repro here. I don't have any clue as to how good the repro is, but they're no longer available from GM.
4
Thanks for the information 69hurstolds! Good to know the part I need is still available.
I've noticed that some listings come with the wiring. Does the wiring not detach at the light. Is the harness point not at the light itself? That would definitely be a first for me (though I've mostly worked on newer cars). I haven't found a good picture of the back side of the light. In this case, If that's the case, I'd probably just add an extra harness.
Out of curiosity, if the "proper" disconnect point is not above the light but at the other end of the wiring, where is this point? Seems like more trouble that it's worth, but I generally like to keep things factory as much as reasonably possible.
Thanks again!
Peter P.
32
Castleton, Ontario, Canada
Thanks again!
I have one of these out in the garage. I can get some pictures later today to show you how the wiring connects.
69hurstolds
8,262
17,796
Just check to make sure they're still available from GM, because just the listing that they have it doesn't mean they actually do. They drop that older stuff all the time. There must be a newer application for it that they still have it listed, otherwise they tend to drop that stuff in a moment's notice and even if it shows a good number, it may not be. Inventory costs them money. Dead inventory really costs them money.
Peter P.
32
Hope this helps.
Mar 14, 2022
4
Thanks for the great info everyone! I really appreciate it. I'll definitely look into this and see what I can do.
rfpowerdude
674
1,076
Palm Bay, Fla
And once you replace the unit, don't put lamp bulbs back in it. Use replacements that are LEDs. WAYYY less heat that causes this problem.
rfpowerdude
674
1,076
Palm Bay, Fla
carnutjw
625
1,475
I have the same light in my 79 Cutlass. Used two part epoxy to repair broken tab. Put an LED in the festoon bulb position. Pics at night before and after, #1 with auto flash, #2 didn't even flash. Seriously brighter, and cooler.
