MONTE CARLO Engine light no ecu
KarateCrotch
Jul 30, 2020
50
10
8
Los Angeles
I still have ecu just nothing going out the firewall it’s been like this for a while now but yesterday she threw a check engine light what could this be she is no longer computer controlled everything is hei or vacuum advanced I’ve only ever had one light on this car and it was the choke 😂
ELCAM
1,131
1,283
My guess is it is mileage driven if you are still using the ECU to drive the gauges. Or it is time driven.
Service warning for something based on mileage or time.
KarateCrotch
Jul 30, 2020
50
10
8
Los Angeles
Thing is she’s a little bit of a project still you know so the most I’ve been doing is flushing the coolant system I’ve driven her but only down the block and yea I’m using the stock cluster still
Jakefromstatefarm
465
923
My guess is an internal fault in the ecu
Bonnewagon
Lost in the Labyrinth
10,599
14,370
Queens, NY
You have two choices. Pull the CEL bulb or pull the fuse on the ECU.
tkruger
358
310
NY
abbey castro
1,060
1,325
Harker Hts TX
I removed the ECU as well as the engine harness (firewall fwd) for it along with all emission control harness/senders and controls. The Check Engine Light came on. Took out the light bulb! The ECU doesn't control the gauges or else mine would not work and they do. The only thing the ECU does control is the speed sensor which is located in the rear by the speedo cable, so remove ECU no cruise control!
g0thiac
939
582
I believe the ECM also controls the lock up on the trans there as well, but there’s ways around it obviously.
Also I think you can use cruise without CCC if you are not scared to do a bit of wiring!
abbey castro
1,060
1,325
Harker Hts TX
I haven't run across any article on how to wire for cruise on 87s. Yes, it also controls lock up function but there is a kit to wire that separate from B&M.
g0thiac
939
582
If I’m correct, I believe you can also use the 78-80 cruise as well.
