FINAL CHOICE… variable or constant
I have a 1" drop with lowering springs and Bilstein B6 shocks all around on my Regal.
The shocks made a huge difference when I went to 17" rims.
hey, i took a look at your YT channel got a few questions from this vid.
what size ae your rear tires, and what are you using for springs on the rear? thanks
Choice is already made, but I love the B6 in my Regal. Soaks up iowa potholes with grace and are as said night and day from the shitty parts store Gabriel Ultras I had before. Idk if it's just me but winter seems to kill cheap shocks. They just never feel the same after they get to -30.
Reactions: 83MonteCarloSS
The rear tires are 295/55R15 MT Drag Radials and I believe the rear springs are UMI 2" lowering springs
Reactions: L05edSS and JimmyD
awesome 1 more ? i see you have/ had a reagle did you do the same with lowering spring and if so what was the rear tire size? i'll be doing a relative post soon and you'll understand why i'm asking.. thanks
Awesome 1 more ? I see you have a Regal did you do the same with lowering springs and if so what was the rear tire size? I'll be doing a relative post soon and you'll understand why I'm asking.. thanks
The Regal is lowered 1" and it has 17" x 8.5" all around with 275/50 rears and 235/50 fronts.
Reactions: L05edSS
I have poly bushings all around and poly body mounts and I have never heard a squeak. I am pretty happy with the suspension and have B6s as well. I’ll never go back to a cheap shock.
how are the polly mounts? i seen some reviews where sayin rattling teeth out their mouths or something....
