the fans rest their weight on the core support than i just bought fan ties..plastic mounts that go through the radiator like i plastic tie strap material.got them at advance in the cooling aisle.How did you mount the fans to the radiator??
Just make sure it's wired to pull and not pushI noticed that you have the same F-body LS1 fans as I have. I haven't mounted them yet, but was wondering what side is top and bottom. The 3 strips of plastic that stick out on top. I was wondering if that was actually the bottom that is supported on the rad support edge. I bought mine already removed.
I suppose it doesn't matter which side is used as long as it's supported well and wired properly.
I've been mocking up the fans on my new radiator support.
topstring said:Just make sure it's wired to pull and not pushI noticed that you have the same F-body LS1 fans as I have. I haven't mounted them yet, but was wondering what side is top and bottom. The 3 strips of plastic that stick out on top. I was wondering if that was actually the bottom that is supported on the rad support edge. I bought mine already removed.
