hi guys heres the run down. i have a 1970 355 with stock heads worked over and probably just over 3k miles since rebuilt was 2/3 years ago. all new electronics with msd module under cap with rev control. spark is good out the end of all wires. intake is edel 7104 rpm. twice now in the last 600 miles the car starts missing. limp it home and pulled the plugs and all are fine except for no 1. its jammed pack full of oil but it has compresion. it has 183 and all others are about 175-185 on the other holes. my local machinists suggest that the intake mani gasket may be leaking but wtf? only 1 hole would be affected? i put it together myself and i'm sure the dam thing didn't move but i dunno i guess its possible but other possibilities are flogging my mind as of late. the heads are old 441's that we tossed in 2.02 and 1.6's and i bowled blended and ported but there were looked over before being assembled so its not like athere a hole in them but i had the guides machined to accept the viton thimble type valve seals like what come on vortec heads instead of the tin shields with umbrella o rings. is it possible that the no 1 cylinder seals could have come loose and would it be able to suck this much oil through the new guides anyway? that last thing i was pondering is that i guess the oil ring is low tension or so and i'm told that if a cylinder isn't firing then the rings will not have compresion to force the rings to seal and then it will suck oil into the chamber. i am currently messing the gov on kmy trans and every so often i am bouncing on the rev limiter and wonder about how it works? like is the msd module cutting spark intermitintly to all or random cylinders when it comes into play or just a single one like maybe no. 1 cylinder. i dunno, got so many dam little things to finish i didn't wanna rip out the intake to inspect. anyone run across this? thanks.
