Front brackets
MC96
458
494
Im assuming he means the accessory drive brackets. If so, they will work on a regular sbc, whether a specific component is compatible with what you currently have is where more info is needed.
Tim & sleek
Apr 24, 2018
91
34
Fort Wayne, In
Does anyone know if the bracket from a 4.3 v6 fit on a 350 v8
Ok people's I was at work when I put that up now I have time to clarify ok I m going to use ps/ac bracket ( left side,driver side ) and alternator bracket on right passenger side from a 2000 s10, the reason is I m going to upgrade my ac and want new style ( not the pancake style ) ac unit. I need to know if my existing ps pump will bolt up to bracket and what alternator is going to fit bracket and hook up to the car. Is their going to be clearance issues?
Streetbu
Know it all, that doesn't
3,760
11,760
Central NY
P/s pump will probably work, tiger accessories will basically have to be from the S10 to fit the brackets. Your G body alternator and a/c pump won't fit the brackets
Tim & sleek
Apr 24, 2018
91
34
Fort Wayne, In
I know the alternator wont fit but how to hook up the new style as in wiring. Will the s10 ps have the right presser for the g body grear box
Streetbu
3,760
11,760
Central NY
Yes, fittings on P/S pump are the same thread and size. Alternator is easy, just get the adapter harness at your local Napa. $12 IIRC I believe it's part # EC82 but double check me
