Fuseable links?
marz442
249
Cicero Il
A buddy needed a jump and I said why not help a fellow G body friend out. I popped the hood and he went to work before I got out. Turns out he hooked the positive to the negative and negative to the positive and now my cutlass won't start or do anything!!! Not even a click can someone please help.
marz442
249
Cicero Il
What's the best way to check it I looked at the two wires and pulled on them and they look good but what's the best way to check it they have power running thru them? Or is there a fuse in the fuse box I should be looking at?
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
how could he get a boost and leave if he crossed the + and - ?.....do your headlights turn on?....if not check the fusible link. If the fusible link is burnt do not replace that with a fuse. For a temporary fix cut out the fusible link and use and 14 gauge wire in it's place
Gozer442
281
259
Ontario, Canada
Take off the battery terminals, clean them, and bolt them back on...and re-torque. I had to do that recently.
