I thought I would start a topic about those little time and effort saving things that make a job go easier or faster. Lets share them and maybe if we get enough it will become a stickie so anyone can browse it quickly. Here's a few I like: When you take an alternator apart and try to put it back together you never can find a suitable pin to hold the brushes out of the way. The thin red plastic straw like you get with a can of carb cleaner or WD40 works perfectly. When removing a parking brake cable from a drum brake backing plate, the retainer won't release. Wrapping the retaining clip with a tiny hose clamp will compress the retainer and out she comes. On a QuadraJet or Dualjet carburetor that has an Ajustable Part Throttle, the APT screw should never be unscrewed without first bottoming it out while counting the turns that the factory set it at. Then it can go back to the factory setting. The screw is a double "D", the same as late Q-jet/D-jet idle adjustment screws. That type socket can be hard to find, but a Q-jet secondary rod hanger with the fat end ground off fits perfectly and the hanger end gives good leverage to turn the screw. Removing the aluminum plug right above the APT screw in the air horn and replacing it with a threaded plug lets you make adjustments without opening the carb. That's a start so feel free to add your own so we can all benefit.
