I'm looking at getting a Comp Cams Extreme Energy 4x4 cam, http://www.summitracing.com/parts/cca-cl12-231-2 , but I want to know what gear ratios would work well with it.
Here are the specs:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 600-4,600
Intake Duration at 050 inch Lift: 206
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 206 int./214 exh.
Advertised Intake Duration: 250
Advertised Exhaust Duration: 258
Advertised Duration: 250 int./258 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.432 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.453 in.
Valve Lift with Factory Rocker Arm Ratio: 0.432 int./0.453 exh.
Lobe Separation (degrees): 111
The operating range is 600-4600 RPM so I think it'd be fine to use with a tall gear like 2.41 or 2.73.
Here are the specs:
