Max tire size OK i know it's been here before.
justdandy
17
5
I have an '84 white, red interior. base el camino. we have a healthy 400 small block, th400r4, 3.83 posi, sway bar frnt and rear.
so I smoked the old tires off now I want to replace the rears.
outside the car is BONE stock. I like the sleeper, it's even quiet, 'till I hit it.
I want to use the original wheels. I like the fat 14" balloon tire. The car rides like a Caddy. don't want to do "rubber bands" I'm looking to folks for Ideas.
I have 205/70R1495s tires now. Rotted
565bbchevy
9,616
12,688
Michigan
I don't know what your original wheels look like but if you got 15" wheels or maybe some 15" rears that match the fronts it would really open up your options for tire sizes and if you ever want a drag radial they typically start at 15" and get bigger from there
pagrunt
9,170
15,357
Elderton, Pa
If keeping the 14" wheels a 215/70R14 would be close to the stock 26" tall tire. 225/70R14 is about an half inch taller, 245/60R14 about a half inch shorter but may be a little wider than recommended for the stock 14x6 wheels.
justdandy
17
5
OK, yea i've got some 15"s on mags on the nova, but that is a different build. that's a kick butt road racer, you know up down around a 45 and up again.
the elky just rides so smooth, I just don't need much, just a little more rubber on the road.
thanks for the help. You brought up the 245 on a 6 ' wheel. I have 6.5" wide wheels. so I guess I better look into that. thanks
565bbchevy
9,616
12,688
Michigan
Are you measuring like this? Where the tire bead sits on the inside.
R.4e9b3b9dfb4e66debeec2622c6d1f1d2
justdandy
17
5
no just using specs. anyway a 245, 235 x14 is not out there i caN AFFORD. GOING TO A 225 70 14 COOPER TIRES FOR NOW 'TILL i DECIDE WHAT TO DO ABT THE WHEELS.
