Went & did some tire kicking
pagrunt
9,168
15,349
Elderton, Pa
Finally picked up the Saginaw tonight. Seller is a car guy but had no idea it was a 4 speed or a Saginaw. He had it ready for me to inspect it & I was surprised with how clean, smooth & tight everything is with it. I have decoded it to being out of a '75 H car but the ink stamped code is well painted over. I haven't did the spin count yet as I just wanted to get the stamped numers checked out. The interesting thing I have come across is all Monza's ran a 3.11 1st regardless of the motor that year. I can't find Vega info to see if it was the same for them too as GM Heritage doesn't have info packs on them but the Cosworth cars do have info saying they only had 3.11 1st too. Regardless Jr. now has a 4 speed for his car & it was only $125.
  • Winner
Reactions: 4 users
spidereyes455
785
1,640
Northeastern PA
ck80
Moderator
Moderator
5,743
9,122
I have that info in my stick shift files. But I have had a 3.11 with no grooves which I found odd, Then there is the '76 3.75 4 speeds in the 140 L4 Monza's. I haven't been able to find any data on the Vega's to see if they had it too.
I can't promise when because... health issues. Hip drilling and marrow extraction on top of all the rest = no fun.
But.
If you recall those 1000-odd gm manuals I picked up from a dealer about a year back, there were Vega and monza factory GM service manuals in the piles.
One of those might have the info you seek in it. Then again it may not. But, eventually when I am up for some bending and lifting again, I dont mind trying to find out if it's in there. Just right now all thr manuals are in computer paper boxes and stacked 5 ft tall.on a pallet.
pagrunt
9,168
15,349
Elderton, Pa
But.
Take your time, heal first.
DRIVEN
8,075
14,536
*CENSORED*
No matter what it is, Saginaw were super deep 1st gear, which compliments lame Gbody rear gears. Good snag.
pagrunt
9,168
15,349
Elderton, Pa
Had some time this morning for us to jump on some stuff. Went over the Saginaw somemore to fin the two grooves on the input shaft which I can't understand how I over looked it. Finally gave a spin regardless & verified it's the 3.11 I was wanting. Found out the GM/ITM shifter mount bracket has a smaller hole in the mount position that uses the tail housing to main case bolt, it's ment for the 3/8 stud but I'll open it up for the 7/16 bolt unless one of those OE 7/16-3/8 studs can be found. Then we tackled the driver side parking light socket. It was a broken ground tab inside being the issue. Must of broke when the bulb was changed. Spliced in a replacement from the hacked extra light harness. Then I found out the ground wire can be unpluged from the harness just to have the contact tab break too. An easy ground wire swap since every thing on it was put together with terminals, just had to retape the side markers junction. Now all the lights work other than the dash right turn indicator but that'll wait until we get into the dash.
pagrunt
9,168
15,349
Elderton, Pa
Per the owners request for keeping things near original I bought him a NOS Landu vinyl roof in the correct color for the car. Just under $45 shipped was something I really couldn't pass up but had to wait a while for the seller to relist it. So the plan is we pull the original & repair/treat all that might be hiding under it. Then if things are ugly & need metal it'll go on. If not it might just stay off & get painted the same color to match vinyl color.
mclellan83
4,270
9,483
Pgh, PA
Man some owners can be a real pain :wax:
pagrunt
9,168
15,349
Elderton, Pa
We got the back ordered Super Brights bulbs for the tail lights today. Now other than the headlights (which will be H4's later) all the exterior bulbs are LED. Since Jr. had a friend over he didn't get to see the joys of pulling out '79-'80 Monte Carlo tail light bulbs as I swapped them out. I knew the flasher fuses won't work with them all in but still tried the turn signals & 4 ways just to ensure everything works which it all does. The brights are dim cause of the flashers arn't the right ones. I'm going to start anther thread on the need for a good set of flasher fuses for LEDs so it'll be there for future searches.
