Need a Supervisor to Chuck's El Camino
Oldscarnut
250
245
NW Washington State
Installing Rallye 350 spec engine in a 1980 El Camino project. (LAST one for sure). Cylinders 1 and 3 had bent push rods, and #3 Pivot was snapped too. I wish I could say it happened at 6500 RPM crossing the finish line, but nope. The old mechanic (Me) didn't get the TDC cylinder as #1 and well 180 degrees off will almost always get the same result. Let's just say I can confirm the damage will happen every time! I attribute it to impatience and the solid belief that I had everything right when I built it and somehow lost the timing. New pushrods a tad bit longer from Adam Mead installed. Thanks Adam! Awaiting the pivot from Rock Auto, and before I put on the valve covers I will watch #1 for no spring compression and start it (I hope) finally. I posted this to reinforce double checking everything before you get excited to crank it over. The real problem of not starting was that the stock push rods were .375 short. Sigh....
:cool:
....HEAVY SIGH!!!
I think I need a supervisor if I am ever to finish this marathon!!
  • Sad
