"Very good you win a cookie"v2vera said:I had the same problem it ended up being the connection that runs from the blower motor accross the engine kind of like by the carb. was burnt up. It was a red wire that wasnt making contact inside the connection once I got that connected worked just fine.. That might be the issue :idea:
No cookies for the wrong answer, High blower does not run off the resistor ,sorry.RITTER said:I want a cookie 8)
tc1959 said:"Very good you win a cookie"v2vera said:I had the same problem it ended up being the connection that runs from the blower motor accross the engine kind of like by the carb. was burnt up. It was a red wire that wasnt making contact inside the connection once I got that connected worked just fine.. That might be the issue :idea:
