need help w/ alternator wiring
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
Nod06 said:
that sucks wonder if I could just wire a light in between the alt and a key on power source??
you can but I think it has to have a resistor in the line which was the lite I believe
Nod06
12
Jacktown,ms
cool il try it out thanks man you are good to this site I lurk majority of the time and i always see you helping out 8)
crucial118
1,055
51
48
MARYLAND, DMV
Do you know what size resistor is needed?
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
it has the size of the resistor in here
crucial118
1,055
51
48
MARYLAND, DMV
Ok. But I see 10 + 2 ohm - 1. What does that mean?
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
I'm not sure if that is a + or a ÷ but I can't help you with that...have to wait till some electrical wizard to shows
jethro442
n00b
Sep 18, 2011
4
Virginia Beach Virginia
Resistor needs to be above 35ohms and below 300ohms. I used a 100ohm from radio shack.
brettlaage03
248
SW Wisconsin
I had a wire harness from another old gm and spliced it in. So all of the starter wires and 2 of the wires that were in there for the alternator have been replaced. So it is wired up correctly. I made some wires a little too long so i'll have to shorten them up later. I put a new starter in and that fixed the starting issue and now have a fuel leak. The lights are still pulsing when the engine is running. I am planning on getting a new alternator, but need to know which one. The engine is a '75 chevy w/ I'm guessing a 60 amp alt. I am going back to an Olds engine soon but its a 350 not a 307. Should I buy an alt for a '75 truck, an '88 Monte w a 305 or one for an '88 cutlass (which is what I have) w/ a 307? They all have different part numbers. I think they all would mount up the same. Does it matter which one i get? Thanks
