Rear seat brace vs bulkhead.
Tony1968
2,324
5,136
NW Indiana
No offense to anyone. I honestly believe that everything is just a bandaid to the real problem. The frame and the old rubber body mounts. Just my opinion but reinforcing the frame correctly and using something harder than rubber (poly) should reduce flex greatly. Having done both i still added the X brace. Jmo.
Clone TIE Pilot
3,869
2,622
Galaxy far far away
I agree, it should be mentioned that rear seat braces won't really work without the #5 bushings installed.
Boxing the frame would be the best fix but its a complex and delicate procedure. To box a frame correctly it should be clamped into a chassis jig and back step welded to minimize heat warpage.
pagrunt
9,208
15,488
Elderton, Pa
With out clamping into a jig might remove the warping from when they were originally put together.
Tony1968
2,324
5,136
NW Indiana
I boxed mine with Hellwig kit. Following instructions to a T. Measured carefully prior. When done it hadn't moved at all. If I remember correctly less than a sixteenth of an inch. Body went back on with zero issues.
-dw-
211
382
Central MN
I wasnt paying attention or ignoring all this bracing all these yrs. I havent changed much on my car for nearly the last 20 yrs. One of the last changes I made way back when were solid body mounts. That surely seemed to firm up the way the car felt.
Tony1968
2,324
5,136
NW Indiana
I believe these are the bushings you speak of...
Reactions: 4 users
doood
Amateur Mechanic
Sep 24, 2020
590
804
After reading all the spirited discussion on the rear seat brace in this and previous threads, I've come to 3 conclusions:
1. Not going to install the tubular bolt-in brace I got from Mike's Montes years ago but never installed
2. Not going to spend $270 for any stamped sheet metal brace no matter how well is fits
3. Will buy strips of 0.100 steel and bolt/rivet install with seam sealer
Was going to use reproduction rubber body mounts; but I'm hearing good things about the urethane.
doood
Amateur Mechanic
Sep 24, 2020
590
804
You have really beefed up the LCA to frame connection with the weld-in and the UMI bolt-in. I have the UMI bolt-in, and will install when I swap in the 8.5 this spring.
Clone TIE Pilot
3,869
2,622
Galaxy far far away
