So i sold the 78' El Camino 454 as some of you know and i bought a 86' Monte Carlo SS. Then engine was supposedly rebuilt not too long ago. He did give me receipts to prove it. What i would like to know is what you think my issue might be.
When driving the car and only when it warms up does it smoke but it does not smoke out of the tailpipes it smokes from under the hood and out the back. The harder you are the worse it gets. I do have oil coming out of my breather capi noticed and also at one poin out of the intake which i did replace the gasket. The engine does over heat and it doesnt take long but only when it sits still. When im driving down the road it will not ever overheat. Do you think maybe the rings are garbage or do you think this could be an issue with the pcv valve and some vaccuum hoses causing this? If so do you think this is the cause of my overheating? The engine has a pretty crappy flex fan on it and an electric fan behind the grille that is not functioning due to the wiring that was previously screwed up. Your help is much appreciated. Thank you.
