I've done this to many steering boxes in 35 years and just want to add a few notes of caution:
The textbook way to do it is with the box on the bench, using a beam-type inch-pounds torque wrench on the end of the sector shaft to measure the drag at the center point of the travel. Adjusting the preload too tight will reduce the steering gear's self-centering ability and it becomes a PIA to drive straight down the road. If you're going to shadetree the adjustment process, do it out on the road. Make a small punch or scribe mark on the adjuster bolt and a reference mark on the housing. Adjust a 1/4 turn at a time, with a drive after each adjustment to make sure the steering centers itself properly. Once you get to the point that the steering won't center itself easily, back it off 1/4 turn and do one final drive. It may take an hour or two to do, but in the long run you'll be glad you gave the job the attention it deserves.
Bill
