bigjoenvegas said:
I was thinking on pulling my dash out and wrappining it in black tweed. Has anyone done it? My dash is really cracked, so I was thinking on filling the cracks with bondo and sanding it smooth, then wrapping it with the black tweed. Where are all the bolts to remove the dash and do I need to remove the windshield? Also I would like to do my own door panels but the top panels are a little tore up. Where can I just get the bare cardboard upper panels?
Joe,
I've seen it done on an El Camino several years ago. I think it looked pretty nice, too. He also did his door panels in tweed as well and some of the other interior plastics. The only thing is, tweed is kind of a dated look. It does look good though.
Of course you'll need to get the dash nice and smooth before trying to apply any type of tweed, fabric, vinyl, even a dash cap.
You might want to even consider using a dash cap.
As for dropping the dash. You'll find a bolt in each corner under the dash. I believe there's one or two along side the steering column (which you'd have to lower, by the way). You'll also have to remove the speaker grilles to access a few more fasteners.
Also where the blower duct outlets are on top of the dash near the windshield, there's several screws in there as well.
You'll also need to disconnect the speedo and some of duct work and wiring.
Just make a note as to where everything goes and you should be in good shape.
You DO NOT need to remove the windshield.
Jack
