V6 exhaust help
CrammerGram69
447
146
SW, Michigan
What are the chances of finding an original gm single outlet v6 exhaust for my Buick 231 car. Local muffler shops want way too much. Anything out there in Michigan?
blk7gxn
1,390
1,886
Greetings! Looks like JC Whitney has all that you need, they list on eBay, Ill provide links to your exhaust pieces you need. Good luck!!
Will
CrammerGram69
447
146
SW, Michigan
Will
Will the first link you sent work with the factory y-pipe crossmember? My car isn't running a Cat converter. Due to thefts, and I hope this kit also works with all of the factory GM exhaust hangers because I do not plan on running those piece of junk Universal ones.
blk7gxn
1,390
1,886
The links I sent are for the cat back, and are factory specific "OEM" so will bolt to your existing exhaust brackets perfectly.
79 USA 1
1,065
2,041
Cheektowaga, New York
Check Rock Auto also, Better prices for equivalent parts. Your only issue may be making a "test pipe" to eliminate the converter.
CrammerGram69
447
146
SW, Michigan
Hi. I did check them but looking for a quality/material correct name brand. Where do I find a cat?
79 USA 1
1,065
2,041
I recently installed an AP exhaust kit in my brothers 89 Mercury Grand Marquis and was quite pleased with the quality of the parts as well as the ease to install. One huge plus on the AP parts...No wrinkle bends which comes with the Walker pipes. As for the cat, Rock shows them out of stock right now for your application but check places such as Summit or Jegs for their oe parts line.
blk7gxn
1,390
1,886
