Wagon rear door vent windows
clean8485
2,863
2,158
Ontario, Canada
Are the rear door vent windows for a wagon interchangeable with '81-'87 rear door vent windows, or are they a different shape?
Ribbedroof
4,925
7,064
Wellston, OK
Wagons are different than sedans, if that's what you're asking....
81msw79
391
125
roselle park , nj
That's what I'm asking. Thank you.
with the rear doors the lower part of door or main door body are interchanchable depending what car they come from. some bodylines were changed. the entire window frame is a different shape but if you wanted to it is possible to pop the welds and swap.
clean8485
2,863
2,158
Ontario, Canada
Looking to swap vent windows in an existing door frame. Thanks for the info.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,177
9,796
Gainesville, Fl
Jeff,
Are you swapping the vents out for power vents, or is the car already equipped with power vents?
Longroof79
Oct 14, 2008
12,177
9,796
Gainesville, Fl
Ribbedroof
4,925
7,064
Wellston, OK
Sure you already know this, but the G wagon windows will interchange across the 4 carlines...Buick/Olds/Pontiac/Chevy all wagon vent assemblies are the same .
Longroof79
Oct 14, 2008
12,177
9,796
Gainesville, Fl
Brian,
You're saying that the basic vent windows are the all same except for the power mechanism, which is added on. For instance if you have a non-power vent window you can add the motorized mechanism to it? Also, can you use the power mechanism from a sedan power vent window?
