Just want some guesses on horsepower and torque what it will run in the 8th mile
i ran a 8.61 befor i changed a bunch of stuff but i had to short shift at 4,800 Rpms to avoid floating valves now i am able to hit 6,000 rpms and it is pulling hard up there.
1981 monte carlo
2500 stall 7.5" 3.42 posi aluminum cover girdle
Boxed lower rear controle arms stock rear sway bar
Tires i dont have drag ratils right now buti may be able to get a set to use.
396 Bord .060 + 408 line holed and decked .010
119CC 2.06/1.75 pass heads large oval port Milled .010 6272292 compression up to 9.7:1
stainless steel undercut valves
Lunati VooDoo 60203 Duration at .050 227 int./233 exh.
Crane Cams 13744-16 Energizer Roller rockers
Edlebrock Performer intake
monte carlo might be a round 3650 if i remaber*
EDIT: for got to add to the list
Speed Pro ZL2328NF30 "36.60cc"
Holley 3310 750 VA with rear mettering block and purple spring.
New valve springs just installed last week was havving bad valve flote with the new cam and the old.
Lunati 73124LUN Seat Load: 136 lbs @ 1.880 in. Open Load: 355 lbs @ 1.250 in
1981 monte carlo
