Pics of hood hinges - steel vs aluminum
L92 OLDS
2,872
3,050
West Michigan
Since this topic has come up several times I thought I would post some pics showing the difference between steel hood springs and those used on the rare aluminum hoods. In summary, the number of windings is the same but the wall thickness of the spring coil is different.
Close up of aluminum spring coil below
FE3X CLONE
2,714
47
48
Ohio
The other way to tell is when you put hinges on a car and the steel hood comes falling down on your head. :evil:
Good post. I have multiple sets of hinges and I know at least one set was for an aluminum hood but wasn't sure.
88hurstolds
1,747
658
Window regulator springs are only 5 coils and are not big enough.
Would be nice to find a good replacement though...
Another way to tell is that you can close the hinge with your bare hands.
83hurstguy
39
6
Kansas City
My steel hood hinge springs on my H/O measured even thicker in places, up to 0.118-0.124". Found that on another set as well. Either way, very clear delineation of difference.
