Would this slip yoke work for a TH400 swapped 86' Cutlass?
sadisticsavage
29
This is the URL of the part= http://www.dennysdriveshaft.com/p1539_t ... html#photo
GM 3R Series 32 spline T-400 & 4L80 Transmission Slip yoke specifically designed to be used on a T-400 & 4L80 with the Threaded Hole in the center of the Output shaft.
This design will replace the truck style bolt on yoke with a car style slip yoke and allow for proper slip travel and bushing contact for best performance.
With this slip yoke you can now use a normal car style driveshaft.
A must for any threaded output shaft on T-400 & 4L80 transmissions that are being used in a car application.
We designed this yoke to solve this problem over 25 years ago.
Barrel Diameter... = 1 7/8 inches
U-joint cap diameter...= 1 1/8 inches
U-joint width... = 3 5/8 inches
Series... GM 3R Series
Spline count... 32
