That's kinda what I was getting at. There's decent street options like cast iron manifolds and shorties, but if you're going racing and want the "really good stuff" you're limited unless you have a bucket of $$. ARH is some of the best. I think the owner's an Olds guy so that's likely the only reason they even have them.Thornton Restorations has cast iron manifolds and tubular SS manifolds that would more than likely fit fine. Neither is a hard core performance option though.
yesI am sure this question has been asked may times but, will a 455 olds sit on the factory 260 or 307 frame mounts. I am just starting this project so any help is appreciated.
I am stuck between a th400 and a TKX 5 spd.Okay, then, pure curiousity here......Dig the big block Olds drop but wondering what you were considering for the rest of the drive train? Auto stick versus 4-spd and third pedal? Built TH 400 or a 700R4 or stouter? Run the factory suspension or tweak it some by plugging in slightly stiffer springs and shocks? Lose those press metal rear control arms in favor of some UMI's or Hotchkis or CPP or????? (The list is endless as to suppliers and everyone on the board has their personal favorites) More horsepower needs better brakes for balance so more thinking and bench racing for ideas about that.
Oh, yeah, pictures, pictures, and pictures. The old business about them being better than a thousand words really rings true around here.
