The New England states are just as bad for salting. Then there are the cars that live on the coast with salt water storm spray!I shouldn't have assumed anything, because I don't know. If Ontario is anything like Upstate NY, then I agree 120%. Buy stock in Cargill Salt mines.
I was curious about the Holley ECU fitting under a CCC carb'd vehicle kick panel. That's a bummer it was a no-go.Tried to mount my Holley Terminator X Max under the dash. Originally I was planning on mounting the ECU where the factory ECU was. The number of wires was not happy about bending into position. It seemed to naturally sit under the glove box.
First attempt proved my lack of skills in the hand drilling and tapping of 4 holes into aluminum. With no center punch or good pattern placement only 3 of 4 holes would line up. Drew up a PDF and had a local shop laser cut this mounting plate for me. Used 4 rubber isolation pads and a Haltech firewall grommet.
