The New England states are just as bad for salting. Then there are the cars that live on the coast with salt water storm spray!I shouldn't have assumed anything, because I don't know. If Ontario is anything like Upstate NY, then I agree 120%. Buy stock in Cargill Salt mines.
I was curious about the Holley ECU fitting under a CCC carb'd vehicle kick panel. That's a bummer it was a no-go.Tried to mount my Holley Terminator X Max under the dash. Originally I was planning on mounting the ECU where the factory ECU was. The number of wires was not happy about bending into position. It seemed to naturally sit under the glove box.
First attempt proved my lack of skills in the hand drilling and tapping of 4 holes into aluminum. With no center punch or good pattern placement only 3 of 4 holes would line up. Drew up a PDF and had a local shop laser cut this mounting plate for me. Used 4 rubber isolation pads and a Haltech firewall grommet.
CCC = Computer Command Control = state of the art (@ that time) electronic control of the carbs on late 70's/early 80's GM cars. The computers were mounted behind the Pass side kick panel w/a 2nd panel covering it.What is a CCC carb'd vehicle?
I mean if I really tried hard. Might have got it to work in the original location but this is a terminated harness. Everything seemed to lay in place. All the connectors are right near the sensors and outputs. Just seemed to naturally want to be under the dash. I kind of like how the LED's will be visible too.
Not looking to sell the brackets but I'd be happy to share the PDF for the bracket with anyone trying to mount a Terminator X max.
