BUILD THREAD 79 Malibu wagon not slow not fast
What did it end up making on the dyno?
The flame out of the exhaust on decel could be caused by a bunch of things, but most likely not an issue. Did the oil pressure come back when it cooled off or with an oil change?
Less than before, for a bunch of un known reasons.. didn't break 300..
my gues it's stupid rich and I have no afr on it. It was missing and felt like it was fighting itself so called it a day and it ran fine home.
I don't have a windage tray, or engine oil cooler.
Just out footing it around I can pull 20psi out of the oil.. normal pressure is a 50-60psi when warm, and idle is around 30-40. That's just short shifting at 3500-4000.. 6000 is redline for engine.
There is definitely a case to be made that I need a windage tray, and engine oil cooler . Will be pulling the engine apart, make sure there is no signs of oil starvation adding windage tray and put a bung in the oil pan for oil temp sensor
And I kissed a guardrail on the way home with . Which I'm still pissed at myself about. My annoyingly luck one-sided racing strip🙄🤦🏻‍♂️
Reactions: mclellan83
On the topic of fuel tanks this came across my FB ads
Thought about the idea of taking the stock tank profile split it in 1/2 front to rear, extend it to the PS some 20-25" , move the fuel level and pickup towards the front center of the tank vs OEM is center center of the tank.. It would roughly double the tank capacity and increase useable capacity as well.
Figured I'd post it here to find it later lol there's a lot of other stuff that needs done first though
Well I'll bump this, IDK if y'all still lock threads...
Been window shopping wheels,
Between full blown wheels or making some C4/C5 17*11 work or possibly some 18*9.5. I don't really want the 19/20" setup..most likely need a 2-3" wheel spacer not really a fan of the idea..
Rough plan, I think, is to keep my 17*9 steel wheels with some 300TW 275/40/17 for daily maybe some RT615s 200tw version, then run middle to upper end of the road on some 200tw 315/30/18
Haven't touched the wagon.. been working on finishing another vehicle project
You can't tease us about another vehicle project and not at least give us one pic of said vehicle
Reactions: Ugly1 and Malibu795
It's a 09 ECSB WT 4*4 Duramax that I wrecked almost 2 years ago, did a frame swap, currently dealing with electrical issues. Mainly related to serial data lines and random burnt wire smell
I can side track my own thread if y'all like🤷🏻‍♂️🤣
mclellan83
Would you like the
short-long
Medium -medium
Long-short
Or make 56kps dial up pass out details on my 09 dmax and 75 GMC K20 that's on a side burner as well🤔🤷🏻‍♂️🤣
Matthew Broderick Books GIF
