Brake Bleeding
Ernest
1,019
1,595
Texas
Its that time again.... not for the mailbu, but for my daily driver(2005 GMC SCSB).
Replacing the brakes on the front(disc) and rear(drum)... consider this a "one man" brake bleeder, crew of one.
This idea has been around for ages, it'll be a great help when working alone, it'll cost very little, plus your time buiding one yourself... versus the ones you can buy pre made.
All i had to buy was the 3/8" OD x 1/4" ID clear pvc vinyl tubing from the local home depot... the brake fluid container to catch the old/new fluid, cordless drill with a 3/8" for the OD tube and 1/8" for the vent drill bits, of which i already had on hand, i took the extra step with the zip ties to lock the tube into the cap, top and bottom side.
How To:
Bleed Proceedure:
This is more dependable than Speed Bleeders, and the two combined is foolproof. Unless of course you forget to refill...
Yes... and it worked out just great.
Alone with replacing the brakes all around... i replaced the both rear drums and both front rotors, it was time.
Reactions: Sweet_Johnny
I use a pressure bleeder (pump bug-sprayer) because I was always getting air bubbles in the vacuum bleeder hose from air bypassing the threads on the bleeder screws on the wheel cylinders. Never had that problem on the front calipers. I did have fine luck with the one-man bleeder bottle but drained the reservoir on the master once and made a lot more work for myself. Once I stomped the brake pedal with the reservoir cap covering the reservoir but not attached at all - this ejected the reservoir cap and sprayed DOT3 all over and was a lovely cleanup. Another time I went to bleed the brakes with a drum off and over actuated the wheel cylinders. I should have a blooper reel. Brakes suck.
I clean the pressure bleeder out with a $3 liter of isopropyl when I put it away (managing the issue with H2O in the DOT3). There is a bit of waste with the extra DOT3 in the bug sprayer, but I chuck all the residuals in the glycol collection tank at the local dump.
Yeah.... the funny thing about them bleeder valves, i like to crack them open first with a 1/4" drive 6pt deep socket along with a 1/4" drive ratchet, 8mm for the rear, 10mm for the front, then used a matched sized small box end wrench afterwards to open and close them easily.
The threads are coarse and because of that, it seems to allow a small amount of fluid to drip even with the tiniest of openings, they should be more of a fine thread IMO and feel more snug like tapered pipe threads so nothing drips, that also allows small air bubbles to be produced, but that would probably suck for the people living up north with all the road salt driving in the snow rusting everything shut, no problem though with those living in the south.
After tightening the rear bleeder screws, no leaks as its a matched tapered end of the screw that came with the rear brake cylinders, but it was a different story for me for the front caliper screws. The passenger side bleeder hex head was next to being rounded off from the prior owner, a 10mm box end wrench didnt work, using vise grips didnt exactly work either as i didnt want to snap the bleeder screw in half. So i did the next best thing, old school trick if you will, i gently hammered on a 3/8" drive 3/8" 6pt deep socket so it would cut into the rounded off hex head, along with a 3/8" drive ratchet, i was then able to crack open the bleeder screw, worked like a charm.
So what i was getting at about the two front 10mm bleeder screws, the driver side was a little worn, but i still ablle to open it up using a 10mm box end wrench, but i decided to replace them both anyways. I went to a local autozone and got the correct dorman replacements, for front calipers only, came in pairs, m10x1.5x30mm, fit perfectly. After the bleeding process was done and the bleeder screw tightend, i noticed slight fluid staining around the top side of the threads that enter the caliper, and it wouldnt stop no matter how much i tightened the bleeder screw, my guess is the tip of the bleeder screws are too broad and not conical enough to seal the flat or tapered hole inside the caliper correctly. So the only remedy is to use either teflon tape, of which i dont care for in this instance, so i chose to use the teflon sealant version on the upper part of the threads away from the bleeder hole, now sealed good, and no more leaks.
EDIT: before teflon paste(pic1), after teflon paste(pic2)
I have always used the old school way of bleeding brakes by having someone pump the brakes and hold them, the problem is that someone isn't always around so for decades I have been using the "Club" steering wheel lock that rachets down.
I pump the brakes a few times by hand and the final time with Club locked and wedged between the seat and the brake pedal I bring it down as I press the pedal and it automatically locks in place.
i always use by trusty mity vac with the container for brake fluid that came with it the container catches the brake fluid no mess never let me down
Reactions: 69hurstolds
I've seen the time I could stick a peice of vacuume line onto the bleeder ( zirk ?)... a get a shop vac then put the other end between my fingers and hold the vacuum hose up to the end of a shop vac hose and control the suction by the spread of my fingers of course you check to see if its sucking too much through usually several ( a few) tablespoons is enough for one wheel...now this is not the way I usually bleed brakes or clutches just a weird way to try sometime if you don't have a helper or vacuume tool..a work around as it's said...it probly won't work every time but then again...
Reactions: Slowpoke
i seen this earlier for which i agree with in terms of ol' skool brakes like our cars but gets into some other points when comes to rear drums. this yr am planning on addressing some of this hopin a new master cyl from acdelco aint gonna new parts curse me in replacing a 39 yr old 1 that still works fine....
That video is definately good for thought.
I just bought a brand new ACDELCO master cylinder for the malibu, install it, then flush/bleed the entire brake system with new dot3 fluid.
I'll see how the brakes feel afterwards on the road, the power brake booster, shoes, drums, pads and rotors are all in good shape, then after all is said and done, i'll replace the rear brake hose along with both front brake hoses for the front, thankfully they are all still availabe brand new from acdelco.
