I replaced the driver's door outside handle. (1988 Monte SS). The spring in the handle had broken so it was kinda loose. The door opened and closed as it should.
After replacing the door handle.....now the door will not latch closed. On the passenger side I noticed that if you push the metal "catch" back it will lock/click in place and you have to pull the inside door handle to allow it to release. On the driver door the metal catch does not lock in place when you push it back (see pictures).
Has my driver side latch failed or am I doing something stupid.
Thanks!
Thanks!
