.Products | News | Policies | About Us | Contact Us | Support | Log In | Create Account |
Subscribe to UMI:
Home :: 1978-1988 GM G-Body :: Rear Control Arms :: 12-Bolt Swap Control Arms :: 1978 - 1988 GM G-Body 12-Bolt Swap Lower Control Arm and Adjustable Upper Control Arm Kit
Product 2/2
larger image 1978 - 1988 GM G-Body 12-Bolt Swap Lower Control Arm and Adjustable Upper Control Arm Kit
Starting at: $314.99
This kit includes both the upper and lower rear control arms designed to bolt a 1964-1972 GM A-Body 10-Bolt or 12-Bolt rear end into a 1978-1988 GM G-Body; this includes Monte Carlo, Malibu, El Camino, Regal,
Grand National, Grand Prix and Cutlass. The upper control arms supplied with this kit are built at the correct angle to attach to the G-Body chassis as well as the A-Body rear end “ears”. These control arms are a must any time this swap is being completed. Using factory upper control arms will cause drastic rear end bind and incorrect driveline angle, this leads to traction lose, vibrations and unsafe handling. The lower control arms are fixed length and center the rear end in the wheel wells, lower arms also feature grease-able Energy Suspension polyurethane bushings and reinforced sway bar holes.
For more information on a specific item please visit each products specific link below-
Adjustable Upper Control Arms- Item # 3019
Lower Control Arms- Item # 3015
Application:
1978 - 1988 Chevrolet Monte Carlo, Malibu, El Camino
1978 - 1988 Buick Regal, Grand National
1978 - 1988 Pontiac Grand Prix
1978 - 1988 Oldsmobile Cutlass
Add to Cart:
Products ...
Secure Socket Layer
Front PageHomePoliciesAbout UsContact UsSupportUMI Performance, Inc. Copyright © 2010
