12" Clutch Question
BobS
n00b
Sep 26, 2015
PA
I'm a "new old guy" and I have a clutch question.
I have an 80 Malibu that back in 1986 I installed a small block 400 engine bored to 406 cubic inches. Over the years this car has sat in the garage and the last time I moved it it had a torque converter leak from setting. I'm not thrilled with the 350 automatic and have started buying the parts to do a 4 speed conversion.
I received the flywheel today from Rock Auto for the 11" clutch. I just happen to have a couple of 11-7/8" clutches laying around in the garage. Some refer to this as a 12" truck clutch. The original applications were 30 series pickups, P30 stepvans, 6.2L diesels, 454's, and retrofitted Cummins 4BT in the P20's and P30's. The pressure plate from this application is a direct bolt up to the 11" 168 tooth flywheel.
So my question is have any of you used this clutch application? I have the 11" bellhousing from OPGI en-route.
https://www.opgi.com/malibu/1981/drivetrain/transmissions/CH26684/
My only concern is the RPM rating of the clutch which would rarely if ever exceed 6500 RPM's.
I know I will need to check the pressure plate to bellhousing for interference. I know that there are bellhousing spacers out there if there is any minor interference.
So does anybody have any thoughts on using this type of truck clutch?
BobS
if the pic shown is the actual bell housing they are selling the ball stud is in the wrong location.
you need factory part number 464697 or 469697 which are pretty much non existent.
if you do find a bell housing with that part number you need the ball stud in the lower location NOT the upper
