On my RideTech setup I've got 750 pound springs, and I'm using 18x9.5 wheels with no rubbing.... weird how our two cars can be so different.
Agreed....On my RideTech setup I've got 750 pound springs, and I'm using 18x9.5 wheels with no rubbing.... weird how our two cars can be so different.
Driven at that height? With what size tires? Not 275's all around.Agreed....
You mentioned your fender lip measurements as 26.25" @ the rear fender lip on the 'Beating a dead horse' thread & that you considered your car 'pretty low".
I saw that & thought.... No, yours is lowered. Mine @ 22/F & 24/R" is "pretty low". 😊
Yes. That was 6k daily driven miles @ that height. Skinny, 25" tall tire on 15x6's up front; 15x8's rear w/a taller/wider 15" tire. No possible way to put anything larger up front as set-up.Driven at that height? With what size tires? Not 275's all around.
True, for common 'short' 2" drop spindles. I don't know exactly where the SSM 'tall' spindle falls is this regard (increased track width).Bigger brakes can push the track width out 5/16 - 3/8" per side vs. stock.
With drop spindles and low BS wheels, you want to put tall ball joints on (at least 1" taller total between the 2), because the stock geometry has positive camber when the tire goes up, moving it closer to the inside of the fender lip.
With tall ball joints, the top of the tire stays neutral camber or moves inside (negative camber) as the wheel goes up.
18x8 front in a 3.7 backset in a polished finish.
This is going to end badly. My money is on you having to compensate with a silly amount of static camber to keep it from bashing the wheel lips to hell and back. Each of these cars (below) has a 17x9.5 wheel with a 275/40R17 mounted... with 3rd Gen F-body backspacing (4.5" or more). The Monte Carlo is the only one without any issues because it has a complete stock front suspension (other than lowering springs) - the Buick and the wagon have had a lot of work to compensate. Order a new set of front wheels.
Not going to order anything new just yet. The tires on it now are about an inch taller than the ones going on long term. If I drop it an inch I am sitting about midway in the adjustment range and it can easily go down further if need be. I will let everyone know how it works out.This is going to end badly. My money is on you having to compensate with a silly amount of static camber to keep it from bashing the wheel lips to hell and back. Each of these cars (below) has a 17x9.5 wheel with a 275/40R17 mounted... with 3rd Gen F-body backspacing (4.5" or more). The Monte Carlo is the only one without any issues because it has a complete stock front suspension (other than lowering springs) - the Buick and the wagon have had a lot of work to compensate. Order a new set of front wheels.
At this point just going to have to see how it all comes together. I appreciate the input and will let you know how it turns out.This is going to end badly. My money is on you having to compensate with a silly amount of static camber to keep it from bashing the wheel lips to hell and back. Each of these cars (below) has a 17x9.5 wheel with a 275/40R17 mounted... with 3rd Gen F-body backspacing (4.5" or more). The Monte Carlo is the only one without any issues because it has a complete stock front suspension (other than lowering springs) - the Buick and the wagon have had a lot of work to compensate. Order a new set of front wheels.
