You DO NOT have a frame notch??I'm running 18x9.5 wheels all the way around with 275/35/18 tires.
you know those b/s numbers for an 18"x10" for a non notched rear ?The 10" rim could fit without notching the frame all pending backspacing and offset.
I notched mine to the seam with 5.25" backspacing.You DO NOT have a frame notch??
what is your back spacing ? 4.5 or more ?
ill be moving up to 17" front and 18" rear once i do my c5 front and l/s rear plate swap with e/ brake!
just waiting on the brackets have everything else
and any idea of how low we can go? have no problem rolling the lips or doin some wheel well re-shaping just dont want o cut a frame .. yet lol
i just looked at your build... All 154 dam pages yesterday lol. But GD those wheels fit soooooo nice !!!! i wouldn't mind being narrower on the tire and get lower and bigger diameter ..I just finished fitting 325s on a 19x12 under my Monte... it only took 6 months.
wouldnt mind a half/seam notch, thats seams lil more reasonable if i have to then say motorheadmikes inside frame boxing extravaganza ...I notched mine to the seam with 5.25" backspacing.
notched?I'm running 18x9.5 rim with a 255/40/18. Just a comparable if you want it.
same.295 35r 18 here on 10.5 wide
No notched frame, stock.notched?
b/s numbers? if you dont mind
love the stance
same.
You 1980 guys have more room out back. Luckynotched?
love the stance
same.
