18” wheels
hello people: I know there's more choices of tire for 18" than my 16". So what's your choice are youz using with the 18"?
IBBY
I'm running 18x9.5 wheels all the way around with 275/35/18 tires.
Reactions: Tony1968
You DO NOT have a frame notch??
what is your back spacing ? 4.5 or more ?
ill be moving up to 17" front and 18" rear once i do my c5 front and l/s rear plate swap with e/ brake!
just waiting on the brackets have everything else
The 10" rim could fit without notching the frame all pending backspacing and offset.
you know those b/s numbers for an 18"x10" for a non notched rear ?
and any idea of how low we can go? have no problem rolling the lips or doin some wheel well re-shaping just dont want o cut a frame .. yet lol
Reactions: Tony1968
I just finished fitting 325s on a 19x12 under my Monte... it only took 6 months. :blam:
I notched mine to the seam with 5.25" backspacing.
i just looked at your build... All 154 dam pages yesterday lol. But GD those wheels fit soooooo nice !!!! i wouldn't mind being narrower on the tire and get lower and bigger diameter ..
wouldnt mind a half/seam notch, thats seams lil more reasonable if i have to then say motorheadmikes inside frame boxing extravaganza ...
notched?
b/s numbers? if you dont mind
love the stance
same.
No notched frame, stock.
Lowered I believe 3.5" in the rear.
Wheel is a 18x9.5 with a 4.58 backspace and a 2mm offset.
I would have gone bigger tire and could have with spacers .. but not a fan of spacers.
You would hit the frame before you hit inner wheel well.
Yeah, don't do what Donny Don't does.
Reactions: Jakefromstatefarm
