18” wheels
MY6.2SS
144
87
Hello,
Those that are running 18x10 on the rear, what size tire are you using?
Thanks for your help, David
Jakefromstatefarm
465
923
I'm running 18x9.5 rim with a 255/40/18. Just a comparable if you want it.
Streetbu
Know it all, that doesn't
3,721
11,525
Central NY
18x9.5 here with 275/35. You can easily run a 285 on a 10" probably even bigger. Just need the room for it.
Jakefromstatefarm
465
923
The 10" rim could fit without notching the frame all pending backspacing and offset.
MY6.2SS
144
87
What do you think would be the widest tire that I could run on a 10" rim before it starts to bulge on the rim?
Streetbu
3,721
11,525
Central NY
305 might bulge, might not, depending on brand. Some run wider or narrower than others
Tony1968
2,313
5,100
NW Indiana
Work in progress
Reactions: 8 users
