Chapter 5, Wiring harness rehab:
The engine is back on the stand. Starting with a factory ('95 Caprice?) engine harness.
Lay it on the engine:
Start with one of these...
...and 3 pages of this...
...and start removing any irrelevant circuits. The ECM plugs are hanging from the hook on the far left.
At this point I'm about 4 hours into it. I've extracted all the ABS, AIR, AC, PS, EVAP, etc. from the main harness and isolated all my B+ and ignition power feeds and grounds along with the ALDL wires. I'm going to utilize the OE fuel pump and cooling fan relays. All those wires will be run through the firewall just behind the EGR. The one thing I don't like is the location of the ECM. It would be behind the driver's side headlight in the donor car. I'm going to have to extend/shorten various wires to change the orientation of that portion of the harness. That should keep the top of the engine from being obscured by a wrist-sized bundle of wires. I plan to run it into the cab near the steering column and locate the ECM on the inside. More to come.
