I used a dual snorkle air cleaner from a 84 Camaro Z/28 and the hood just closes. RamAir manifolds from a 67-70 GTO fit nicely. I used a Jeg's double hump transcrossmember with my th350. The hardest (read most frustrating) part was the accessory drive.
The only mounts that work properly are the ones from a G-body 301/265. the basic frame mounts are pretty much all the same, just the placement in the frame my change but you must have the proper block mounts. Use a 70-up block since the proper block holes are all there. If you use a 69-down block, you need a adapter from Ames.
Other small parts I used were the throttle cable, schroud and fan, power steering hoses from the 301. Throttle cable brakets are different for pre72/post 73 intakes so make sure you have the right one for the intake used. You also have to transfer the fuel line to the left side along with the battery.
