jim said:
Alright!! I ended up taking the throttle plate off of the original carb and slapping it on the '73 due to the fact that the vacuum booster for the power brakes didnt have anywhere to plug into on the '73.. Should any problems arise from that?
Yeah, there's no vacuum to the power piston for one. I'm sure there might be some other issues as well. Basically it's not a wise choice. Heck I didn't even know you could swap throttle plates between late and early model Qjets....
Anyway it sounds like you are a novice when it comes to cars. That being the case you should keep things as simple as possible or you're just going to bugger something up and get frustrated. IMO, you should just get a late 70's Chevy-style ( aka side fuel inlet ) Qjet. I'm sure there are plenty of 80's non-CCC Qjets that came on trucks too that you can use as well. If the linkage on any of these carb aren't quite right to hook everything up perfectly like on your stock carb, then swap the throttle linkage from your original CCC carb to the other carb. You will probably not be able to do this yourself but you shouldn't have much trouble finding someone to do this.
In the end you need to do the 'right' thing and that means you have to suck it up and spend a few bucks. Don't try to do cobble up some POS and get it to work correctly because you'll just end up paying more money in the long run. Do it right the first time and you'll be happy you did.
