Bonnewagon said:Good for you. Safety first!
19cutlass79 said:2.11 crap gearing
Black Sheep said:19cutlass79 said:2.11 crap gearing
Don't mean to be a dick, but 48 divided by 21 is 2.29, not 2.11.
Nice car, hood took a lot of work 😀
T19cutlass79 said:punched a drain plug in the gn rear just for ease of changing fluid, there was a dimple on the cover already figure that's where they were planning on making one so figure just do it you know.
got the moser axles and new wheel cylinders installed.
installed intrax 1" drop springs.
before: I should have took better strait on pic's before dis-assembly, oh well 😀
after, with new brake's and aluminum drums
This morning I was going to start to tear down the front, change out the control arms as I have spohn lowers, and HR parts uppers, and the 1" intrax drop springs, but beermonkeys last post has me hesitating a bit, he has the 1" drop in the back only right now and his exhaust is hitting the ground! I have duals out of stock manifolds, so I asked him what part of his is hitting, if it's header collectors I might be safe as running exhaust manifolds gives some ground clearence.
Here is the front with tired stock coils, car originally had a 301 now has a pontiac 350
The dimple is where the little doughnut shaped magnet was supposed to be. It's too high to drain the diff you will still have a couple of pints left in there after you pull it.![]()
wade
bawazir said:Why dont you give me that rear end buddy,
