=======================================================================================================19cutlass79 said:Took her out for a spin today idled her around the block one way then the other to get the fluid in the rear sloshed around good to the new axle bearings, the car steering doesn't pull but feels a little squirly at low speeds I am going to take her in for an alignment just to have everything squared, coming up a long street near my house I decide to get on it it stumbles in first carb needs a rebuid I think and fresh gas, I mashed it rolling at 15mph after the stumble she just screams, I let her upshift to thrid get off the gas and smash it again to see how the downshift and the secondaries are working and it works good, it chirps on the down pulls hard then BAM! something let's loose and I hear something bounce off the undercarriage and road then I get a little vibe in the drivetrain and a little sick as I limp her around two corners to get to my house put her in park check the trans and oil fluid all good jack up the front take the tires off check all the new suspension parts, good, jump back in the car start her up fine, run through the gears in the garage trans engages fine, shut it off start swearing in my head only thing left is the rear end. Jack it up on stands , turn the wheels by hands no clunking sounds or broke sound, just to be sure I pull on the axle to see if the c clip went, nope, so I get under it look at the rear yoke and thank the powers that be, I blew a u joint cap which is weird checked the torque on the bolts still good, so I think that joint straps maybe stretched out so I bought new joint and straps, I will try it again tomorow, that concludes this edition of ratty wagon chronicles.
Wade
Wade,
It's a good feeling when you're able to get the car run motoring under it's own power. They'll always be bugs that have to be worked out, but geez, you made a heck alot of progress on the car.
As for the u-joint, it's a good thing you weren't too far from home, and that you didn't totally drop the driveshaft.
Keep up the good work.
