Thanks 69hurst It broke where the cable from the head unit connects. I tried pulling up on it in all positions and I cannot get it out. Any idea what way the slot is in the box??Hopefully you can reuse yours, but if you break your threaded rod clip, you can buy this one for 15 bucks (or $6 plus shipping on the website), or you can hope to find GM p/n 1224062. They're pricey AF because the Corvettes use the same clip. So....
78-88 GBody HVAC Heater A/C Air Temp Blend Door Pivot Lever Arm ROD RETAINER | eBay
When you open your glove box door and look behind it you will see this pivot & retainer assembly by your duct work. Heater A/C Temp Blend Door Pivot Arm. ROD RETAINER. Located on the inside HVAC box behind your dash board on the passenger side.www.ebay.com
Can you do this with everything attached but the glove box? Silly question I knowIIRC, you have to make sure all the connections are off the lever, then you need to turn the thing clockwise (CCW if you're looking up from the bottom). I might be backwards on that. But the thing is, there's slots in the housing that need to line up with the wings on the lever and it should just lift up and out. It's not like the slots are huge, so turn it slow while slightly lifting up. That's about the best advice I can give you. You MAY be able to reach it better if you take the glovebox totally out, but it's been so long since I done one, and my mind is dissolving, apparently.
I got it out! You were right with the clockwise if you are looking down on it. Thanks again for the help!!!Can you do this with everything attached but the glove box? Silly question I know
Mine broke while taking out the radio in my 88 Caprice, plastic broke trying to remove the AC/Heater cable.Hopefully you can reuse yours, but if you break your threaded rod clip, you can buy this one for 15 bucks (or $6 plus shipping on the website), or you can hope to find GM p/n 1224062. They're pricey AF because the Corvettes use the same clip. So....
