Hey rodney, did you re-use the steel you cut off the frame rail or did you cut a new piece from new steel? Either way the work you're doing looks great. Keep up the good work!
Bluemalibu7d8 said:Hey rodney, did you re-use the steel you cut off the frame rail or did you cut a new piece from new steel? Either way the work you're doing looks great. Keep up the good work!
motorheadmike said:It looks great. But, if you are into it this far why not just go with tube frame rails vs. a skin of the factory rail? It would look cleaner and be stronger. The way it is now you will need some gussets on the inside of the rail skin to the bracing you've added.
