1985 el camino frame
sitopons
n00b
Jan 31, 2009
2
Does anyone know any companies or junkyard (like for el caminos) that might be able to supply bare frames for el camino, an also what years of el camino will fit an 85.
Also any companies outthere that can replace the frame because it looks like a big *ss job...
thanx homies
'78-'87 El Camino frames are all the same. The only exception is that in '83 they added an extention to the transmission crossmember mount to accomodate the 200-4R trans. If this is the trans you have and you get an earlier frame, they sell an adapter so you can make it work.
Slight correction - after 83 had the extension. So 84 on had it.
i'd appreciate it if you let me know if you find someone scrapping good frames. mines ok, but that'd be cool if it was reasonable.
you should check out ElCaminocentral.com
They will be able to tell you were to get one. I think what you could do if anything is buy a vary cheap El Camino around you and take off the body. It will save you for other parts for the frame you will need later
DUDE!!!! I just scrapped a perfectly good frame today!!!! and NOW i see this topic. sorry for your luck. although i do have modified frame for an el camino but it is basically backhalved though. if your interested im about 10 minutes from illinois border. st louis mo side
let me know what you think
nick
Should have an 85 frame in about a week or so....where you located?
